OKAY, things are COMPLETELY ASKEW here and I may fire the pool girl...oh, wait, that's me
Well, I can't explain our findings except to say there is something very wrong going on around here. I'm afraid I've completely failed to produce any kind of meaningful result for anyone else whatsoever.
First off, here's where we're at this am:
FC 5
CC 0
PH 7.4
TA 80
CH 40
CYA - 40* this looked lower than last test
BORATES 40-ish -* this looked lower than starting before test
Copper .3
Iron .3 - back down .1 ppm from higher test mid week
SALT - 2400, BOTH the strips and Taylor kit corroborated, as did Hach meter at pool tech co's -- so I lost about 500 salt...presumably vacuuming to waste
PHOSPHATES: 50,000 PPB?????!!!! SERIOUSLY?
First, we tested -- using the Hagen aquarium kit that uses 3 reagents, goes to 5,000 ppb, with a 6-tone color chart just like the pool kit. We used a 2 mil dropper for measuring with great care, plus several 5 mil test tubes. We used distilled water from a jug.
We did the following combos, with the pool water always being at 5 mil until the 50:1 test, at which point I dropped the pool water to 1 mL.
1:1 Dilution
1:2 Dilution
1:3 Dilution
1:4 Dilution
1:5 Dilution
1:6 Dilution - STILL a solid and deeper blue than the 5 ppm or 5,000 ppb color mark...though starting to lighten compared to first few dilutions.
Then hubby threatened to go on strike if I didn't let him test 10:1 dilution.
In 10:1 dilution, the color tone looked around 3.5-4 ish just like it did BEFORE WE TREATED WITH THE SEAKLEAR.
So then I tried to figure things out by doing a very careful whopping 50:1 dilution and testing with Taylor Pool Phosphate drop test that goes to 1,000. You guessed it, got color tone for 1,000 -- x 50 for 50,000.
Hubby, using same sample with Hagen aquarium kit test which is sensistive to 5, ALSO got a color tone that at 50:1 suggesting 50,000 ppb.
SO THEN I WENT TO THE POOL STORE TO TEST IT AND THEY TOLD ME IT WAS BETWEEN 500 TO 1000 with their "PRO" test strips that go to 2,000. IT NEVER WENT DARKER THAN 1,000 PPB.
So, I'm just kind of losing my mind by now. I am pretty certain there is not really any way on earth my PO4 could be as low as 500 - 1000 even after 2 gallons of phosphate remover, but I am now headed off to another pool store that tests with "a powder" to see what they get just to try to triangulate these disparate results
BUT FIRST, I tested the DISTILLED WATER we're using for dilution at home and get somewhere between 125 ppb and 200 ppb on the Taylor Pool PO4 test.
So the distilled water is not the culprit.
PET THEORIES:
1. Hubby's estimated 37,000 ppb was wildly inaccurate and we were dramatically higher. No way to find out now. Do think he was multiplying by 10 when it should have been 11 but that only accounts for another 5K.
2. There is something in my water that is interfering with reagents. Metal? That would be ironic!
3. Pool store's test strip is useless. In which case many people who think they have "x" amount of phosphate likely have much more????
4. PO4 testing is a dark art.
5. Water temp, from 72 degrees on initial treatment, dropping 10 degrees over 6 days, arrested reaction? Or vendor sold me expired SeaKlear? But it went milky, meaning there was def lanthanam in there!
6. Lack of calcium to bond with and carry out PO4 (per Jack's magic tech theory) negatively affected efficacy.
7. ALL OF THE ABOVE PLUS SOME OTHER KIND OF VOODOO.
So, I'm heading off to try one more test and scratch my head, do another calculation, and possibly sadly determine that I'm calling off the SWG install Monday and returning the unit until such time my liner fails and I truck in fresh water.
OR I might decide to go ahead and just see what happens...if I even got a year and a few months out of a cell, it'd be something of a wash based on my chlorine cost (use 12% refils). So I wouldn't actually mind that for the convenience of constant dosing IF IT produced adequately. I just don't want to deal with sporadic mystery failure/hassle.
I am a little bit tempted to just go ahead anyway.
I will consider all votes on this one, so feel free to throw in your two cents!
