Thread: Stamped Concrete Sealer!
    Apr 2009
    Raleigh, NC
    120
    Does anyone have experience with stamped concrete? We are looking to re-seal ours and are wondering what sealer to use. Also we have a fabricated stone waterfall and since we converted to SWG we also want to seal it, can we use the same sealer?
    NCSalt! IG - Mountain Lake 21x40/Vinyl Liner Fiberglass stairs/Hayward Sand Filter/Polaris 3900 w/Booster-pump (5060)/SWG Aqua Rite-Prologic-T-15 cell/Hayward Elec. Heat Pump/2 skimmers/Gallons: 18900/900 sq ft stamped concrete/Concrete Coping/TF100-Test Kit Hot tub: Dynasty Spa/Neptune Series, 5-person, 400 gallons, carbon filter plus 2 regular filters, LED color lights. "I control my pool, and not the other way around":-)
    Sep 2007
    Lafayette, Louisiana
    344
    Re: Stamped Concrete Sealer!
    Here's a link to a previous thread.
    concrete-sealers-non-slip-additives-t7583.html
    I have stamped concrete and love the look of it. It does tend to get a little slippery for bare feet when wet. I would absolutely recomment going heavy on the non-skid when you apply it. It doesn't really change the appearance and it does need some added texture.
    This sealer does give a glossy/shiny appearance. I'm sure it would protect your stone waterfall, but not sure if you'd like the glossy finish. It might make it look a little fake. I think you might try to find a different sealer for the stonework. Something that soaks in and just makes the water bead up and run off. I['m sure someone else will chime in soon too.
    Jim
    Fortune favors the well prepared
    The build...
    viewtopic.php?t=3974
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    More details as they happen...
    Apr 2009
    Raleigh, NC
    120
    Thanks Belldiver!
    I will take a look at the link you provided, and I appreciate you pointing out that the shine would make the waterfall look "way to fake"...I will use on that what you've suggested to keep it rather matte looking.
    Cheerio!
    Mar 2007
    San Rafael, CA USA
    12,082
    We seal our textured concrete (trowled, not stamped) every year with Glaze ‘N Seal Multi-Purpose Clear Sealer and it works very well. It is a little slippery or shiny for a couple of weeks, but then settles down to a nice looking finish that preserves the life of the concrete.
