Is this normal?
adamt
Feb 10, 2016
37
Los Angeles, CA
So I've noticed a lot of debris floating around with the light on. During the day, the water looks clear.
Is this a problem I need to tackle or is this normal?
I just cleaned the filter this morning, after doing a drain and refill to deal with high CYA.
Yep, normal. There is always stuff blowing in the air and getting in the pool. It will all get filtered out eventually. It is worse at different times of the year for us. The fact that you can see that little bitty stuff is actually good. That means your water is very clear.
