Have been reading and lurking for a while.
The home I bought last year has a 20x40' inground liner pool. Salt/Forgot my controller/cell model.
Pump is a Hayward SP3010X152AZ
The motor is a Emerson/ Model #- R63CXDRE-239/ 1.5/.18 THP/1.0 SF
Motor is two speed- 3450/1725 and 230V
Also has a Hayward Sand filter but I did not take a picture of the model #
When I bought the home I did not pay attention to the main pump motor leaking at the motor/pump seal. But it made through the summer and needs to be replaced. I have a separate booster pump for the Polaris cleaner, I believe it is 3/4 HP.
I am having a hard time finding a cross reference for the correct motor. I am not sure about the square/round flange. I want to order a pump rebuild/seal kit to replace everything when I pull the motor.
If anyone has suggestions on where to find a two speed motor like the one I need it would be great.
Next I will be looking at either rebuilding or getting a new filter. The pool is about 8-9 years old. I am getting a little water leakage on the filter top by the spider valve.
Thanks in advance for any links, or ideas. I am not really sure if I even have the correct sized motor and pump, because the homeowner before me seemed clueless about the pool. He just had it put in and called people when it did not work.
