Help with sealant for porous tumbled travertine
tstex
2,177
Houston, TX
Hello to All,
After finding a way to get the calcium off my spa waterline stones, here is my next challenge. :eek:
After I sand off the calcium deposits from a porous tumbled travertine, are there any brands of water sealants [make/model] that you can apply to stone water-line tiles in a pool/spa that will prevent calcium penetration?
Maybe this will help:
Stone: Tumbled porous travertine, 6" sq's light brown color
Water type: chlorine based pool/spa
Application: 6" tumbled travertine stones where water line comes up 3" to middle of stone. Want a sealant that can be applied to all 6" of stone to prevent Calcium from penetrating stone.
Is there such a product that can do this? if so, could you pls forward the product and any experience [good or bad[ that you have encountered.
As always. thank you very much for your help & advice. :)
tstex
I don't think so. Sealing the tile will make it easier to clean off perhaps but it will not eliminate the Calcium deposits.
Finding and apply a sealant to your waterline tile may end up being a big project. I think it may be easier to keep your pool numbers (CH, pH and TA) in line and just clean the tile more frequently.
Thanks Dura, I believe you will be correct. Maybe bc I am still at just less than one yr of a new pool, there is excessive leaching, so hopefully I'll can bring down the CH. It was originally filled the first time at the end of Jan 2015.
Thanks again, tstex
