Here is how I have my EZ Touch programmed:
Pool 9:00AM - 2:00PM. 1100rpm. (Pool mode, makes chlorine and skims at this speed and cheaper to run)
High 11:00AM - 1:00PM, 3100rpm (high, for in floor cleaner)
Because POOL is running at the same time as HIGH the SWG remains energized and in operation.
These get adjusted as needed but are my base. Note that the higher speed is laid over the low speed. Pentair logic is that high rpm trumps low rpm. If pool was set for for the higher rpm and I then tried to reduce speed the motor would continue to run at the higher rpm
Pentair logic is not.
