I'm in the same situation as you, although in Australia (started running the pool seven weeks ago, waiting for my K2006C from America).
A tip I read on here for reading the higher FC is to dilute my sample. I do one test normally (DPD tablet - I don't have FAS-DPD yet) and I can see that my sample is 5 ppm or more. I then dilute another sample of my pool water by measuring 150 ml pool water and adding 300 ml tap water (which the city says is less than 0.04 ppm Cl). Then I test again, and I can see the colour gradient better. So for example, if my diluted sample reads 2 ppm, then my pool water test is around 6 ppm.
Dilution reduces accuracy due to measuring the amounts of water, so I actually measure 150 ml of pool water, then 150 ml of tap water, then 150 ml of tap water again, all in the same cheap-as measuring cup. Then stir well for my 1/3 FC cocktail. The other weakness is my use of tap water, which I could cure by picking up some distilled water for the dilution.
FWIW, this has really helped me through this early stage of my TFP journey!
