Thread: Goldline GL235 Solar Controler??
    Apr 2009
    Lebanon, TN
    19
    I have ordered a GL235-GLC-2P-A controler for my solar assembly I am installing it comes as a pkg and includes a 3-port 2" x 2-1/2" valve can somone tell me which ports are which size? I am having a hard time finding 2-1/2" PVC bushings. I assume all of the ports will be threaded? It is supposed to be here on Monday and I want to have everything I am going to need to get started with the installation. I have contacted Hayward and have not heard back from them, I hope someone on here has one or something similiar.
    Thanks
    Keith
    24' x 52" AG All Aluminum
    2hp 2speed 200sf Cartridge Filter
    Goldline AquaTrol
    4- 2x20 Sungrabber solar panels
    Goldline solar controler
    Re: Goldline GL235 Solar Controler??
    That valve has connections that fit either 2" or 2 1/2" PVC pipe using PVC cement. It is not threaded and you do not need any kind of adapter if you are using either 2" or 2 1/2" PVC pipe.
    Apr 2009
    Lebanon, TN
    19
    So if I am using 1-1/2" pipe I can glue a 2" x 1-1/2" bushing in it and i will be good to go?
    Goldline AquaTrol
    No, you will need a short section of 2" pipe. The 2" pipe connects to the valve and then the reducing brushing connects to the 2" pipe and then 1 1/2" pipe connects to the reducer.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    A 2" to 1.5" bushing should be 2" port x 1.5" slip, which will fit straight into the valve just like straight pipe.
