CSI and balanced spa water
Mar 30, 2015
133
Dallas, Texas
Does the csi number matter for above ground spas or is that more important for inground pools?
Reason I ask is my,hot tub is at -.8 csi. Partially because my TA is 40. But for some reason having the TA any higher than that causes the PH to always be around 8.
Sent from my SAMSUNG-SM-N910A using Tapatalk
If you added 50ppm borates to your water, then you might be able to raise your TA up to 50-60ppm since the borates will act as an additional pH buffer. Then you can probably get your CSI a little higher.
Any advantage to do this or since csi isn't a problem should i leave as is?
It is highly recommended to use them in a chlorine spa. Borates add to the buffering capacity of the water and are very good at slowing down pH rise. In a hot tub, as you have found out, you typically want to keep your TA low as the outgassing of CO2 from the hot, jetted water creates a large pH rise. The problem is, if TA is too low, you can crash it to 0ppm and, in turn, crash your pH as well. So borates not only add buffering capacity against pH rise but also let you operate at a lower TA without fear of crashing the pH. They are also considered a supplemental algaecide and so you might see reduced chlorine demand using them as well.
As pooldv pointed out, there is a sticky on the use of chlorine in hot tubs and part of that sticky talks about the benefits of adding borates.
