2dog,
You made the following statements in Post #6 -
No more burning eyes, bleached bathing suits, or white scaling. I have 12 clients that would back me up and not one would go back to chlorine. Copper has better disinfection properties than chlorine, thats why many countries are using it for public pools including the U.S.
Burning eyes have nothing to do with proper use of chlorinating products. Burning eye's are typically caused by the presence of combined chloramines, especial the very irritating nitrogen trichloride. High CC's indicate improper use of chlorine products and improperly maintained swimming pools. I have personally swam in my pool up to shock levels of FC (28ppm FC with 70ppm CYA) and my eyes never burned at all. Same is true for swimsuits - they get bleached out when people improperly chlorinate their swimming pools.
White scale has nothing to do with chlorine use. White scale is typically calcium carbonate scaling and it is caused by pool water that is not properly balanced in terms of CH, TA and pH.
Copper is NOT a better disinfectant than chlorine, quite the opposite in fact (links will be posted below to scientifically peer review data).
In the United States it is absolutely false that mineral ionization systems (Cu, Cu/Ag, etc) can be used as disinfection systems. The only EPA-approved sanitizer for commercial/public pools are chlorine, bromine or the non-halogen biguanide (Baquacil) sanitizer. Commercial/public pools may install mineral systems if they so choose, but all commercial/public pools are required to maintain a residual sanitizer level (1-3ppm for Cl) and report both CC levels and track fecal coliform levels. If CC's get over a certain level, most commercial/public pools are required by law to shutdown until the CC levels return to normal. Mineral ion systems can do nothing to oxidize & remove organic bather waste.
Now on to your claim that Cu is a better sanitizer and your use of single journal article to make a point. The fact is that copper ions can act as a sanitizing agent for
certain pathogens and nuisance's such as algae. But, the
facts are these - Cu alone is too slow a sanitizer (as measured by CT kill rates) and not broad-spectrum enough to be a reliable method for keeping water clean and healthy. The paper you cite specifically uses both Cu
and Ag ions in conjunction with chlorine
and it only looks at one pathogen -
Legionella pneumophila. The paper also specifically looks at
hospital drinking water systems as it's primary area of study since
L. pneumophila is known to be difficult to kill with chlorine and is a major cause of preventable, in-patient hospital deaths. A hospital in-house water distribution system is an entirely different system (closed water system) than a residential pool. Therefore, the paper you cite, is at best an apples-to-oranges comparison.
Now, if you want the real science on chlorine versus mineral systems, Richard Falk (aka,
chem geek) has written many posts on the subject. You can find the two most informative posts
HERE and
HERE. If you are truly interested in the science of it, then I challenge to read those posts as they contain not only actual data showing that Cu and Ag ions are less effective than chlorine across a broad range of pathogens as well as links to actual scientific, peer-reviewed data.
As I said, I'm happy minerals are working for you and the pools that you care for and I'm glad you find this site informative. You are free to take care of your pools however you wish, but, you are not free to make up or post misleading information. This site deals in facts and science and the facts are conclusive - pool water treatment through proper use of chlorine and chlorine-related products is the cheapest and easiest way to maintain a pool. Everything else is second-best and more expensive.
