Yes, you need to put your salt numbers in if you have salt in the water. The reason why salt changes the CSI is a bit of technical/mathematical chemistry discussion. Basically, having salt in the water affects some of the chemical parameters that you normally think of as constants. An example would be freezing point. Pure water with no salt freezes at 32F. When you add salt to water, it's freezing point gets depressed to a temperature lower than 32F which depends on the concentration of the salt water mixture. The same is true for other chemical reactions and parameters that go into calculating CSI. Some of the "constants" used in the calculation are not actually constant but depend on the concentration of salt in the water.
I won't labor the point any further except to say that, if you have salt in your water (and everyone, in fact, does), then you put that value into PoolMath.
Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
