I read that it is less efficient to keep FC numbers too high so I am not doing my SLAM perfectly. Although, there is improvement in depth of green color every day. I brush and vacuum every day. I like the Jandy Leaf Master, it even picks up sand and silt fallen in from our rock waterfall. I also found this under Miscellaneous on TFP site - so I feel a little better about acid washing my cartridges:
What is a sign of cartridge failure? increased pressure? dirty return water?
- If the filter has a coating of alage, calcium carbonate (residue from calcium hypochlorite), iron, or other minerals, soak the cartridge in a solution of one part muriatic acid to twenty parts water until all bubbling stops.WARNING: Failure to remove all oils and cleaning solution before acid soaking will result in a permanent restriction of water flow and cause premature cartridge failure.
