Thread: Best way to store cleaner when not in use
    Mar 2009
    Woods of North Florida
    148
    I had planned on keeping my automatic pool cleaner in the pool all time, even when it wasn't on, but crud gets stuck on the floating hose and doesn't make it to the skimmer. I guess I need some sort of box to keep it in, but wouldn't it need to have holes to drain out the water so it doesn't get mildew in the bottom? Any suggestions? What works for you? Thanks!
    24' Seaspray Evolution CLX Above Ground Pool (~13600 gallons)
    Pentair Sand Dollar SD60 / 22.5" filter / Maximum Flow Rate 60 GPM
    Pentair Dynamo Pump 1 1/2 HP
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Best way to store cleaner when not in use
    What kind of cleaner is it? A suction side Kreepy/Barracuda type?
    Mar 2009
    148
    A suction (Wanda the Whale). I'd like something I can put right next to the pool so I can just drag the cleaner out of the pool into temporary storage. For now we are keeping all the other pool stuff in an outside storage shed that houses our lawn mower, but that is several feet away from the pool. Thanks!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Pool cleaners should be removed whenever someone is swimming the hose or cord could entangle a swimmer and drown them
    What you can do with Wanda, when she's not in the pool is get a milk crate, prop it up on a few bricks and place her in it, this will allow drainage and ventilation. The hose won't fit in there but you can get a Hose Hugger (velcro strap with a handle) to keep it all together and either lay it next to Wanda's crate or hang it by the handle. Please remember to drain the hose so that algae or other nasties don't form in the stagnant water
    Luv& Luk
    -Ted
    Mar 2009
    148
    I like the idea of the milk crate! Thanks!
