Thread: Need new heater. Is Low Nox required in Texas?
    May 2008
    Houston, TX
    20
    I need a new heater but can't justify the cost for a heat pump. Looking at gas heaters but was wondering if low nox is actually required in texas. I live in unincorporated Harris County.
    22k gal free form gunite w/spa, Aqualink RS-8, Jandy Aquapure SWG, 2 Jandy ColorLite, Polaris 280, Raypak 400k Low NoX Heater.
    Re: Need new heater. Is Low Nox required in Texas?
    Yes.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    May 2008
    Houston, TX
    20
    Thanks! Too bad, cuz there's a $250 rebate on the Jandy LAARS...non low nox.
    Now you understand the rebate...
    I think all manufacturers are in the process of only offering Low Nox but it is only required in TX, FL , and CA as far as I know.
    If you shop around a bit you should be able to get a reasonable deal on a heater...not a lot of heaters being installed going into the summer months or with the economy.
