I've been quoted $53,573 for the proposed pool - can I say to the builder that I will sign a contract with him if he reduces the quote by $4,000?
Or do they start at the quoted figure and then throw in features or equipment to make it easier to swallow?
POOL:
v 29’ x 15’ Free form Design 379 square feet of surface area
v 4000 PSI Shot Crete concrete pool shell.
v 3 extended Steps in the shallow end
v Swim out or bench in the deep end
v 3’ x 5’ Pool Depth
v Pebble Tec interior surface, Lifetime warranty
v Decorative water line tile.
v Over flow pipe to automatically vent excess water from the pool
v Three adjustable return inlets for maximum circulation
v 2 Main drains to code
v Schedule 40 PVC piping used on all plumbing and pressure tested
v Skimmer
v Stabilization rock under shell (up to 5 yards for dewatering)
EQUIPMENT:
v Hayward Tri Star variable speed pump with magnetic drive motor
v Hayward Star-Clear Plus 175 SQ FT Cartridge filter
v Hayward Aqua Rite 40,000 Gallon (Oversized) Salt Chlorine Generator
v Hayward Heat Pro 110K BTU titanium heat pump including required electric hook up, dual digital thermostats
v Paramount Paraglow blue or white LED light
v Concrete equipment pad poured to house equipment
Builder will "throw in" a robot (probably Hayward) because I removed the in-floor cleaning system from the quote
DECK:
v Three 6" Raised Areas, tile face (deco tile included)
v 3' wide Sheer Descent waterfall
v 655 SF. of Deck (tile on Lanai remains)
v 2" deco drain
v 12" x 12" footings installed into "virgin" soil
v Termite treatment applied prior to installing any decking
v Deck and Lanai installed with Brick Pavers. Color and pattern choice (I have to check this)
v 3 process soil water jetting and compaction system
v Pavers are set on a 6"-8" road base or morrow. (crushed limestone rock/crushed shell/ clay)
v Bull nose coping
SCREEN ENCLOSURE
v Mansard screen enclosure, Bronze, 1 door (replace existing screen wall on lanai side)
v The screen enclosure is under separate permit from the pool. All permits, installation and warranty is honored and performed by pool builder.
v Nylo-ProTec Screws/Caps installed on the entire screen enclosure with a 10 year warranty against rust and corrosion. (compared to powder coated zinc screws that rust and corrode in short order)
v 7" Super Gutter
NO HIDDEN COST/ ALSO INCLUDED:
v REQUIRED Battery alarms to code
v All permitting costs
v All state and local taxes
v All Labor cost
v All electrical cost
v Pool school and maintenance lessons
v Maintenance kit including vacuum head, vacuum hose, 18” brush, telescoping utility pole, skimmer net and chemical test kit
v Pool maintenance for 1 month
v Final grade and total clean up
v Repair of track left after removing screening from lanai
POOL:
v Skimmer
EQUIPMENT:
DECK:
v 2" deco drain
v Bull nose coping
SCREEN ENCLOSURE
v 7" Super Gutter
v All Labor cost
