Pool water not flowing consistently
Sep 10, 2015
11
Houston
Hi, I just bought a house with an in-ground pool. I noticed the pool water was not flowing consistently the day before yesterday. Water flows rapidly for like 10 seconds, then gradually slows down to a complete stop, then flows rapidly again. This goes on and on. Is this something wrong with my pump?
I am pretty sure you will have the bubbles in the pump basket.
Pump running, go to the skimmer and see if your water level in the pool is lowenough to allow the skimmer to suck air. If so, add water to the pool and it will stop.
Thank you! So all I need to do is to add water to the pool, right?
I have not checked the pump basket. Will do it when I get home. If there are air bubbles what should I do? Thanks!
What is happening in the pump basket? Look for air bubbles.
Welcome to the forum.
No, you need to check the water level first as Dave suggested.
........Pump running, go to the skimmer and see if your water level in the pool is lowenough to allow the skimmer to suck air. If so, add water to the pool and it will stop.
Dom
