JJ,
Ok, well if you had a 25K cell, I would imagin 10 or 15% output might do you well since you have an enclosure and some shade. But as mentioned, there isnt a set rule.
The only rule is, if you pool needs FC, then bump up the output or increase the run time. But I dont see you having a large chlorine demand unless the whole neighborhood comes over.
how many hours a day do you run your pump now? Do you run it all at once continuous or break up the run times throughout the day or night?
The SWG is generally wired on the pump circuit, so if the pump is running, the SWG is 'on'. But thats not always the case, there is another option. It depends on what works well for you.
Some people like me want the pump running not because the water needs filtered, but because I like to see water moving if Im at the pool. WIth my SWG wired into the pump circiuit as it was, I was over chlorinating. So to remedy that, I installed a Timer specifically to turn on the SWG on a schedule several times a day. If you can create a schedule, then you can dose....dose.....dose....dose... a little chlorine at a time over the course of the day, instead of ddddooooossssseeeee all in one whack. Multiple doeses a day will let you keep your FC a little lower also, which result in adding to the life of the SWG cell. - Food for Thought -
