Thread: Pool opening - step install on salt pool
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    I read a thread here in the fall telling how to take out the ladders when the salt had corroded them into place. Someone gave advice on a particular lubricant to put on the ladders before installing them in the spring. It will prevent the bond from occuring between the ladder anchor and the ladder itself.
    Does anyone have any advice?
    The avatar is Spalding from Caddyshack
    18x36 vinyl IG - approximately 24000 gal
    Jandy SHPM1.5 Pump (1.5 HP); Jandy APURE 1400 SWG; Polaris PB4-60Q Booster Pump; Jandy CL340 Cartridge Filter
    (3) 4'x12' Aquatherm solar panels
    Next project, pump sound enclosure and lots of pool landscaping [6tons of stone 8) funnnn]
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    Re: Pool opening - step install on salt pool
    OK, I found it: can-t-get-the-ladder-out-t9761.html
    I should have looked harder before posting.
    The answer was marine grade grease.
