Results 1 to 14 of 14
Thread: Deck/ Coping Sealers ???
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    I would like to get everyones opinion on Decking/ Coping sealers. I am in discussions with my pool builder concerning the look of my flagstone surround around the pool and spa. It looks as if it is fading/ lightening as time goes on. Furthermore, it tends to have that sandy, gritty feeling when you rub your hands across it. He dropped off a bottle of "Diamond Clear" Protect a Deck. This is what it says on the side of the bottle:
    "Protects & Preserves Cool Deck, Aggregate, Masonry, Concrete, and Wood Decking.. Reduces Staining caused by Minerals, Algae, dirt, and grime.. Slip resistance is maintained.. Reduces Chalking, Cracking, and Flaking..Environmentally friendly.. Reduces water absorption."
    Does anyone have experience with any type of sealer on flagstone? If yes, please chime in and give me some pros and cons. I am all ears. As it stands now, I plan to do a sample test this weekend on a piece I have left over from the build. Thanks for any input....
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    We had a wood deck with flagstone patio at our last house and I used an approved sealer. It prevented some of the staining that you can get, but in some areas, it showed a white-ish film when wet. It wasn't a big deal, but I noticed it. When dry, it did have a little more sheen (slightly darkened), which was nice.
    Around our pool though, I don't have any plans to seal the flagstone. I figure a VERY light pressure washing a few times a year should keep it looking good.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    RAA's Avatar
    Mar 2007
    The Woodlands, TX
    46
    divnkd101,
    Is this sealer solvent or water based, does it look glossy? What did you use as a barrier to stop the spray from going into the water?
    -Rick
    ~15k Gal IG
    Gunite/White plaster
    AquaLogic PS-8 w/SWG
    divnkd101's Avatar
    Mar 2007
    587
    It leaves no type of glossy finish, etc. Furthermore, the directions state that no masking, etc. is needed in/ around the pool. It dissipates within the pool.
    MIKE
    Mar 2007
    Houston, TX
    167
    I recently sealed my flagstone coping and inlays.
    Some types of flagstone are more durable than others. Ideally you would use a hardener first, then an impregnator/sealer after that. The hardener bonds deep in the stone and keeps it from flaking. The sealer repels water. There are sealers that do not change the color of the stone (stone looks dry) and there are color enhancers (stone looks wet).
    I chose a color enhancer and a sealer all in one because I like the dark appearance of the Oklahome Wister flagstone that it gets when its wet.
    The product I used is Enhancer Pro from http://www.stonetechpro.com/. It was very easy to apply with a 4" sponge roller and an extension handle. I only had about 200 sq ft and I was able to put 2 coats on in about an hour and a half.
    So far I am very happy with the results. My flagstone looks nice and dark and produces much less dust than before.
    Mar 2007
    Southwestern Ontario
    51
    Quote Originally Posted by divnkd101
    This part is concerning. I would think it would not be a bright idea to introduce any unnecessary chemicals into the pool. Hopefully chem geek or one of the other pro's will chime in on what dropping this stuff into your pool water will do.
    If its truly harmless I would not mind sealing the concrete and interlock around my pool.
    62,800 Litre IG Vinyl
    Sand Filter
    1HP Super Pump
    Clearwater/Zodiac LM2-24S SWG
    Aquabot Turbo Robot Cleaner
    250K NG Heater
    divnkd101's Avatar
    Mar 2007
    587
    I definitely had my concerns. The kids were not allowed in for at least a day. Plus, I did have the pumps on and running. The overspray was so small during application and water tested fine the following day.
    MIKE
    Baton Rouge, LA
    237
    TheOne,
    How's your sealer looking?
    Anyone else with sealer experience (good or bad)?
    I'm wanting to seal my "old" bricks that I used for coping and spa veneer, and also the "bluestone" that I used for spillover.
    Ideally, my sealer would achieve a wet look, but not leave a glossy film... probably too much too ask... but hey, have not because you ask not...
    steve
    18,000 gallon gunite free form, with spa, 4x160, EasyTouch, SWCG, Pentair cartr filter, Colorlogic lights.
    divnkd101's Avatar
    Mar 2007
    587
    Steve,
    Diamond Clear did not do the job. I have moved on to a new type sealer I am trying. I was planning on putting a review in this weekend. I am at work and I don't have all the information with me. My PB dropped off a quart and asked me to be the Guinea Pig with testing. So far, the one section of Flagstone I have done is sealed (Beads up when water falls on it) where on other sections, the water just soaks in. I will get my review in this weekend with some photos as well.
    MIKE
    Baton Rouge, LA
    237
    Good deal, looking forward to reading it.
    My larger concern is my "old brick" coping and spa veneer. I don't expect either to deteriorate quickly, but it won't be easily replaced either. I love the way it looks wet... dark, but not glossy... seems hard to duplicate with a sealer.
    My spillover is supposedly "Tennessee bluestone"... I like it, but i could be relatively easily replaced if needed. Then again, its wetted daily, so I'm thinking that it should be easier to make "look" good.... since it's basically hid by the water running over it.... but of course, it's pretty susceptable to erosion, and perhaps corrosion.
    A good puzzle to be solved...
    GregH's Avatar
    Aug 2009
    Dripping Springs, TX
    32
    Re: Deck/ Coping Sealers ???
    I followed TheOne's link above, and found a different product specifically for SW pools. Does anyone have any experience with this product?
    DuPont™ StoneTech® Professional Salt Water Resistant Sealer
    Features and Benefits
    • High performance protection against salt water damage
    • For natural stone and masonry surfaces around salt water pools
    • Protection against water-based stains
    • Preserves natural look
    • Easy-to-use, water-based formula
    20,0000 gal gunite IG pool, built May 2016. Jandy VS ePump, Jandy 60sfDE filter, AquaLink controller, PureLink salt water chlorinator, with Pentair Rainbow in-line chlorine feeder. Use a Taylor Total Poolcare DPD test kit. Heated by the Texas sun.
    Has anyone sealed fladstone successfully. Was there a SWG being used? Im having some deteriooration but dont know if its the salt or traffic. I want to treat the stone but dont know what to use.
    thanks
    Oct 2011
    Frisco, TX
    47
    I'd like to know this too. New pool. Tennessee crab orchard coping and walls.
    Size 13,000 gal | Filtration Jandy DE 60 | Sanitation PLC1400 SWG, Rainbow 320 | Placement in-ground (IG) | Coping Tennessee Crab Orchard
    Finish pebble smooth Tahoe Blue | Pumps Intelliflo VS+SVRS 3.0HP main | Lighting Jandy LED Spa/Pool
    Location Frisco TX US
    Jul 2015
    White Lake, MI
    2
    I need to replace the sealer in my expansion joint between the pool concrete deck and the brick coping. However, there has been either some letting of the coping or some sinking of the concrete decking. It's not enough to cause major reconstruction or concrete jacking maneuvers but in some places there is as much as 3/8" to 1/2" height difference. The brick coping is slightly higher than the concrete decking.
    Using a self leveling material will leave an unsightly lip sticking up. Is there an alternative caulking material that will equally serve the purpose but will allow me to fill in the gap of these unlevel surfaces?
    My name is Tony. I've never done this before but here goes. I am 65 years old. I live in a Detroit, MI suburb. I have a 31 X 13 in ground fiberglass pool and a separate unground spa. I have a cartridge filter and a Raypak heater.
