Thread: Flow Meter
    Flow Meter
    I want to install a flow meter so that I know for sure what my GPM is. That way I can make sure I get a new filter that is going to turn over my pool in 8 hours. My questions, what is a good one to get? I have 1 1/2" plumbing. Also, where in the system do I install it?
    46k gallon vinyl, Intelliflo VF, Quad DE 100, Autopilot DIG60, Raypak R405a, Bravo Fury Auto Cleaner
    Re: Flow Meter
    The Blue and White 300 series is a good choice for residential pools. They require a substantial length of straight pipe for mounting and you need to purchase different models depending on if the pipe is horizontal, vertical water goes down, or vertical water goes up. Be careful that you get the model that corresponds to your situation as not all of the resellers list the orientation clearly. I have seen them as low as $60, though mostly they go for a little more than that.
    Re: Flow Meter
    where in my system do I install it? Just before the filter?
    Re: Flow Meter
    Where ever you have a substantial length of straight pipe.
    Re: Flow Meter
    ok great, that would be before and after my heater.
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Re: Flow Meter
    I totally agree with the Blue-White recommendation. If you mount it in the last place before returning to the pool (after the heater), you will get a true reading of what's going into the pool. On big commercial systems, they use an influent and an effluent gauge!
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
