Results 1 to 7 of 7
Thread: Budget SWG for In Ground Pool ~24,000 Gal
    I was wondering what some of the less expensive SWG's were that would work for a 24,000 GAL in-ground pool. I'm currently using the BBB method but I am strongly considering the switch to Salt for the simplicity.
    24,000 G, Sand, IG, Vinyl
    Jul 2007
    Brisbane, Australia
    874
    Re: Budget SWG for In Ground Pool ~24,000 Gal
    Autochlor SMCA20 (max 30,000 gallons) , or even better SMCA30 (max 48000-50000 gallons)
    especially if you make use of TFP Supporter's special
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    You probably won't find a less expensive SWG than the Intex, BUT you don't get what you don't pay for (frills.) Here's a link to a past post with info on Intex, and how bleach usage can point you to the right SWG size -
    http://www.troublefreepool.com/intex...ool-t8884.html
    Best Wishes!
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
    Quote Originally Posted by Strannik
    I would be interested in getting a quote from you on these products. I haven't really set a budget yet and for me that means that I am not even in the stage of looking for a SWG, more like just information gathering at this point.
    Quote Originally Posted by New2Me
    Best Wishes!
    That's odd. My pool size is definitely over the limit for the SWG, BUT I don't use as much chlorine as it can put out in one 12 hour cycle so I assume that I could still use it. Very interesting, I have already recommended this unit to a friend for his above ground pool.
    JoshU's Avatar
    New Orleans, LA
    545
    What is your price range if you don't mind me asking? That may help us in pointing you in the right direction.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Honestly, I really don't have one right now. I'm just looking into it.
