You should rinse with tap ……….tap water so the vial will be clean for next time.â€
Exactly as I’m doing from this point forward (and did in the post below)
Both the FC and CC test are done with a single sample.
Got it
“If FC was 0 and CC was 5, the sample will not turn pink when you first add the R-0870 powder. That just tells you that the FC is 0, you then add the five drops of R-0003 to see if there is any CC.â€
So my prior post about “quitting the tap water test†was an error on my part. Now I got it. (I’ll be cutting & pasting all this stuff in my pool school document that I’m doing, I’ll eventually get it but there is plenty of stuff here)
Do you have the pump running for at least an hour before doing a test? You want the pool water well mixed before you test it.
Yes. Its 24/7 until I get it balanced for 4 days in a row, at which time I’ll cut it back to 12 hours off in the coolest darkest time, gradually scaling to 8 hours ON I assume. Chime in if the “4 days in a row†is ideal, Carolinians chime in if you’ve found 8 hours to be decent (I’ll get the # of hours of 100% sunlight in my post as I am determining that (and my shoe size, hair color etc- joke)
Got it
