combined chlorine test question
Aug 12, 2015
52
Teutpolis, IL
I have been in SLAM process for over a week with little results. Pool still not clear at all. 4 ft pool 14000 gallons and can only see down about 2 feet but it is blue, not green. Combined chlorine has always come up .5 or less. Today I did the test and put in R-0003 from the TFT-100 test kit after figuring out my FC and it was clear or less than a drop would have cleared it. I then finished eating and forgot to dump the water so then about 10 minutes after completing the test the tube has pink water... do you have to wait awhile after adding the reagent or look at it immediately. Does letting it sit give false positive?
CYA high -80 so we have been maintaining a chlorine level of 31 and starting to run out of drops and getting frustrated.
This is a new house to us and not used to pool. We live extremely close to a flour mill. Any chance it is dust and too fine for our sand filter to really get it out?
Pay no attention to the test after it sits more than a minute or two. Slam often takes more than a week, so you may not have any issues other than just waiting it out. You might try adding DE to your sand filter to speed the process. There is a tutorial in Pool School on how to do it.
You want to do it right away...don't let it sit.
Can you post pics of what you are dealing with?
Are you passing the OCLT (Overnight Chlorine Loss Test)? You shouldn't lose more than 1 ppm overnight.
Have you ever checked for metals in your water?
to save on reagent when you are testing high FC values, fill your tube to 5ml and each drop is then 1ppm of FC. not nearly as accurate as testing with the 10ml, but when you are at 30+ I think its ok. plus counting to 60 can be difficult too :)
In regards to metals before I found tfp I had taken sample to pool store. They stated Iron was .7 and copper .1 They sold me 2 bottles of some metal stain remover or something and I was supposed to use a bottle and half. I put in one bottle and figured see what it did first. Pool didn't look better and tried the other pool store in town then. They said iron .3 but copper 0 and that was after the other treatment. The second was bioguard deale-Alex system and first uses clearcare expert computer program. One of the pool stores had my pool down as 17000 gallons and other had 13000 and I measured it to be 14000. The tft-100 kit doesn't measure for metals does it so I can't measure for them on my own.
The mill produces a brown dust supposedly that settles on the pool floor and easy to vacuum according to the old owner. I saw it when we looked at house and it vacuumed right up not stuck to floor at all when he showed us how to use the pump. No brushing was needed. I cant see the bottom of my pool but figure that is what is settling on my ladder some. I have been brushing and vacuuming daily even though we can't see what we are doing and only skipped one day as couldn't help it but chlorine was still tested that day. The pool is in full sun all day.
Last nights OLCT was 0. We loose quite a bit during the day 6ppm but the pool is in full sun (the solar cover in pic is shot and is giving off little plastic pieces so it is not used.) Been trying to maintain FC at 31 since CYA is 75-80
bought a bag of media for de filters .. hope it is right. put some in filter and first time seemed to get white blown out but second time it was ok. Hopefully it will help. Overnight chlorine loss was zero, combined chlorine is zero but still cloudy
Really need it clear for next weekend birthday party.
We put in enough to let it rise 1 after just a few minutes and quit adding so managed less than a cup. The psi is up 4 now from normal (what we assume is normal - what it was right after our backwash)
We even changed pressure gauge today because wasn't sure we could trust old one and it had condensation in the inside so it was difficult to read anyways.
Normally, you should add a little, check in a half hour, add a little, check in a half hour, etc. until your pressure goes up only by 1psi. You MAY have put in too much.
Keep an eye on your gauge and be prepared to backwash tonight if it rises 25% over "clean (pre-DE) pressure.
We had originally done that quit when the pressure when up by one. We ended up backwashing this morning as pressure had gone up so more but think it because it actually filtering junk from the water. We could see the fourth step today so that was an improvement -- couldn't see it clearly but could see it so progress finally. We have had 0 chlorine loss overnight for past 2 nights. combined chlorine is 0. Should we let the chlorine levels go down or keep them up until water is clear? Water is still cloudy but after adding the DE we are finally seeing progress and hopefully it will be clear by the weekend birthday party and hoping our IL weather holds out and we get some warm days. The cold rain really brought our pool temp down the other day.
