For giggles I upped the CH to 5 (recommended level for my CYA) and I'm going to keep SWG and pump time as is and monitor for the next few days. I cannot imagine that my SWG @ 75% cannot maintain 5 ppm. I'll update with my experience.
NOTE - Please use the terminology "FC" or "chlorine" for bleach additions. "CH" means calcium hardness and you'll just confuse everyone if you use that.
Let's just do a little math (PoolMath really) -
IC40 daily production rate - 1.4lbs Cl per 24 hours
So, if you run 8 hours at 75% power you get -
(1.4lbs-Cl(g) / day x 16 oz / lbs) * (8hr / 24 hrs/day) * 0.75 = 5.6 oz of Cl gas
If you plug 28,000 gallons into pool math and go to the bottom section entitled "The Effects of Adding Chemicals", put 5.6 in the field and select "Chlorine Gas", then you get -
raises FC by 1.5, lowers pH by 0.12 and raises salt by 1.2
Standard daily loss rate of FC for a clean pool in full sun can be anywhere from 2-3ppm/day or as much as 4ppm/day if it is really hot.
Therefore, your net rate of FC loss/gain is going to be -
FC(added) - FC(lost) = Net FC per day
1.5ppm/day - 3ppm/day =
-1.5ppm/day
So even if you increased your output to 100%, you'd still only have an FC input of 2ppm/day which would barely compensate for your FC loss to sunlight, etc.
Bottom line - you need to run your pump for more hours OR at a higher speed to circulate more water through the IC40.
