Thread: filter casing leaking from underneath?
    My filter is leaking from what looks like the underneath little stand it sits on....does this mean my case is cracked? If so I hope my home warranty pays for a new filter..if so i guess it would come with new grids?
    built 4/08/2000 16 x32 460 Sq FT Pool 16,000 gallons 3.5 ft 5 ft 3.5 ft sport pool
    Re: filter casing leaking from underneath?
    also do the rainbow chlorine in-line feeders go bad? Seems like when i open my sometime it is dry looking in there..but when i take the cap off the water rises up? Not sure what is going on
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    How much water is coming out? It's possible that the housing cracked, but much more likely that it's just water trickling down to that point. Check very closely around the lid o-ring, plumbing bulkheads and drain plug for even the smallest trickle of water (may even just look like a calcified water track).
    In line feeders can certainly go bad. All the stuff they use to bind chlorine tabs together builds up and gunks up the works around your check valve and flow control valve. A good way to fix this is to use liquid chlorine instead If there's no water getting in then the problem should be with your flow valve.
    Its a pretty stead stream...not just a drip..i checked the ring and the top air release and it isnt that..its coming from under the case itself and its imposible to see under there whats going on...i am hoping they just replace the whole thing
    sounds like i need a new inline feeder too...its working but not as well as it should i believe
    Ok another question...pac fab fitler is still leaking from underneath...but i also i dug two holes not far from my equipment pad...as i was digging i came upon a pvc pipe..not sure what this pipe is as my waste pipe runs to the other side of the house....what pipe could this be? anyway i wonder if this pipe is cracked and leaking because that side of the house the grass stays wet and holds water...i thought it was my sprinkler system but i cut it back and capped it where it is no longer close to where my yard is damp....i dont understand that pipe that could go to..any ideas?
