replacement panel
What kind of pool is this???? Most above ground pools I know of are one piece sides. I have seen some multi piece ones but they are far and few between. If you truly have one, you will need to drain the pool, disassemble the section that needs replacing and install the new piece. After that it is a matter of re-assembling and refilling.
Got any pictures we can see?
