Question about CYA and FCC relationship.
It's a chemical fact known since at least 1974 as defined definitively by the equilibrium constants determined in this paper. It was known even before then, but all of the equilibrium constants had not been worked out. The bottom line is that the active chlorine (hypochlorous acid) level that determines the rate of disinfection, killing of algae, and oxidation of bather waste is proportional to the FC/CYA ratio (when CYA is present). So if the CYA rises over time and you don't proportionally raise the FC, then the ratio drops which means that in the presence of sufficient nutrients algae can grow faster than chlorine can kill it.
It's not just the FC/CYA relationship that the pool/spa industry chooses to ignore, but also the following chemical facts that are independent of concentration of product or of pool size:
For every 10 ppm Free Chlorine (FC) added by Trichlor, it also increases Cyanuric Acid (CYA) by 6 ppm.
For every 10 ppm FC added by Dichlor, it also increases CYA by 9 ppm.
For every 10 ppm FC added by Cal-Hypo, it also increases Calcium Hardness (CH) by at least 7 ppm.
