Results 1 to 11 of 11
Thread: O-ring lubricant??
    rogerbrks's Avatar
    Round Rock, TX
    172
    O-ring lubricant??
    Any recommendations?
    21,200 gal IG gunite, CL 580 sqft Cartridge filter, aqua pure salt system, polaris 480-blue&white, Jandy PDA Remote, (4) Jandy Deck Jets
    Guest
    Re: O-ring lubricant??
    Magic Lube (teflon) and Magic Lube II (silicone). They are made for pool/spa use and most pool supplies carry them or you can get them online from several sources. There is also a Magic Lube with Kevlar fibers to help stop small leaks from old O rings until you can get them replaced.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Personal opinion, I'd go with the Magic Lube II . I've used the Magic Lube with the teflon in it the past two seasons, and it gummed up my O rings pretty badly. The stuff doesn't want to wipe off all that easily, either. I'll be using the silicone version this year to lube up everything.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Guest
    The silicone version is just as gunky!
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    I'm with mike. Once the teflon version hits water it turns to a white, sticky goo that's more of a mess than the silicone which spreads more easily and doesn't get all goopy. I keep both, but I usually only use the teflon as a lubricant for already-taped threaded fittings or as an emergency back-up to the silly.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hey all and especially Tim, in this post I mentioned the silicon lube weakening/ softening my fingernails - any input?
    Also, for those who go to pool stores that only carry Hayward products - which kind is Jack's 357?
    Thanks dudes
    Luv& Luk
    -Ted
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    I haven't had any problems with that that I've noticed, but I have pretty thin flexible fingernails to begin with. When they grow out at all I can bend them backward without any discomfort. TMI?
    Mar 2007
    4,160
    Luv& Luk
    -Ted
    rogerbrks's Avatar
    Round Rock, TX
    172
    Found a tube of Multi-purpose Lubricant-sealant w/ PTFE. Is this a good one to use?
    Guest
    Quote Originally Posted by rogerbrks
    Is it designed for pool use? The ones we were discussing are.
    rogerbrks's Avatar
    Round Rock, TX
    172
    The sales person at the pool supply store recommended it.
