Hi Uncle, pump run time of 8 hours with SWG at 25% will give you only 2 hours of SWG run time per day. It all depends on the FC output of your SWG vs the amount of FC you are losing to the sun, however 2 hours might not be enough. It's always better to err on the high side with FC. It costs next to nothing to run the SWG for an extra hour or so but it will cost you plenty if your FC falls below 4 and you get an algae outbreak.
Also if your SWG doesn't run when you circulate to the spa it might be better to run the spa after you've run the SWG on the pool. That way the spa water is replaced with freshly chlorinated pool water.
