Thread: Proper testing explanations and pics from Taylor Technologie
    Arizona
    925
    I've noticed many people having trouble determining whether they are evaluating tests for CYA correctly among other tests.
    The Taylor Technologies website has a lot of information on proper techniques and a few demonstrations or pictures.
    Here is a link to what you should see when you test for CYA. (Scroll down for pictures)
    http://www.taylortechnologies.com/Chemi ... ntentID=44
    Here is a link to seeing colors, such as when you test for TA.
    http://www.taylortechnologies.com/Chemi ... ntentID=35
    Here is a link which you will find another link "view demo" which will show you the FAS/DPD test method.
    http://www.taylortechnologies.com/Chemi ... ntentID=11
    There is a plethora of great information at their site. Hope you enjoy it and find it useful.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    ktdave's Avatar
    Katy, TX
    888
    Thanks Buggs, that is very informative.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Round Rock, TX
    529
    Exactly what I needed, as I have this issue;
    5. I got a purple endpoint instead of a blue endpoint when I did a hardness test. What happened? There are metals interfering with the test, most likely ions from algaecides, pipes, or even the source water itself. To avoid this problem, add five or six drops of titrant to the sample before adding the buffer and indicator, then proceed normally with the test. Always include the number of drops of titrant added at the beginning of the test¬*¬* when counting the total number of drops required to reach the endpoint.
    So what is titrant that I should add before the buffer and indicator?
    I'm using the TFP testkit, does it include titrant?
    thanks,
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Quote Originally Posted by lovingHDTV
    thanks,
    In the CH test, the titrant would be R-0012. I'm not sure if Dave has renamed the regents in his kit but it should be the last reagent you add then count to determine the ppm.
    Dave
