Results 1 to 13 of 13
Thread: Old Polaris 180, dead booster. Replace pump or get a 360 ?
    I have an old Polaris 180, it works fine (rebuilt it last year) and I've been very happy with the performance but now the booster pump is dead (motor bearings).
    I've recently adopted a more 'energy efficient' approach and I'm thinking about upgrading? to a 360 rather than replacing the booster pump, however, I have no idea if the 360 is comparable in performance to the 180 with a booster? I don't want to compromise much on cleaning power.
    I have IntelliFlo pump.
    Should I just get a new booster pump/motor or is the Polaris 360 a comparable alternative ?
    Is it possible to run the 180 without a booster pump ??
    Thanks
    24,000 gallons
    58" x 13" ft.
    concrete with PCV linen
    Heat siphon 5hp
    Aquamatic pool cover
    SWG: Zodiac Clearwater LM-3
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Old Polaris 180, dead booster. Replace pump or get a 360 ?
    It depends on the set up of your plumbing. A picture would be helpful if you get a chance. If you have valves on all your return lines, or a three way valve that splits off to the booster pump before any other returns, you could possibly direct enough pressure to the 180 with the Intelliflo. But the booster-requiring APC's work on high pressure, not high water flow, and by running it off your filter pump you subject all your pressure side components to that increased pressure. The pressure at the end of the hose needs to be 30 PSI for a 180.
    The 360 is a better alternative. It only needs 15 PSI to operate. In some cases it might not work as effectively do to the limits of the pump and plumbing, but with the right valve setup and the Intelliflo it should clean as well as the 180 does.
    I'm about to replace all the plumbing on the pad so adding valves is easy. Filter damage would be my main concern (Hayward S-244T Sand filter 62GPM).
    Currently I have 2 suction lines to pump, pump to filter, filter to Tee for Booster
    Main line continues to chlorine tablet feeder and 2 return lines
    Booster Tee goes to Booster pump then booster line
    All suction and return lines have valves except booster line.
    If I close both return valves and crank up the pump that might work without damaging filter ? (Obviously removing pump and adding plumbing direct from booster Tee to booster line)
    My other thought was to install a valve to bypass filter etc while Polaris was running. i.e. valve before filter to divert flow straight to the booster line ?
    All that said if the 360 works just as well as the 180 I may go that route. Hadn't thought too much about 'the right valve set up'. I was thinking of using the booster line as a regular return line after filter etc and putting the 360 on that.
    Thanks
    24,000 gallons
    58" x 13" ft.
    Heat siphon 5hp
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    i personally like using the HAYWARD booster pump for the polaris and letro cleaners. less expensive, less noise... easy install... im a big fan of hayward. Also the hayward booster pumps run the polaris and letro cleaners just fine...
    i had a customer who use the non booster pump 360 and i must say it did a nice job... they turned off other returns to give the cleaner more power and it moved just fine.
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    You need to run filtered water to the cleaner. Some of the smaller things that will pass through a skimmer or pump basket will clog the screen or the cleaner itself.
    Thanks spishex, looks like I'll be ordering the 360 .
    24,000 gallons
    58" x 13" ft.
    Heat siphon 5hp
    Guest
    Actually, I feel that the 360 does not perform as well as the 380 with a booster. It really depends a lot on your pool, the number of returns, your pump size, etc. but from my experience booster pump models just perform better.
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    I'm with Waterbear (and, I used to be a rep for Polaris, years ago). IF you can manipulate your other returns to give the 360 the proper flow, well, OK, but otherwise, the booster pump cleaner tends to work better.
    Now, if you have an Intelliflow (4 x 160 or the true variable speed), one advantage is you can program that pump to run the cleaner, too. Why purchase another booster pump if you already have the rpm choices?
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    The Intelliflow can't produce quite as much pressure as a booster pump, no matter how you set it up. Some of the pressure side cleaners require full pressure and some don't. Take care when selecting a pressure side cleaner to go with an Intelliflow, and be sure it doesn't require full pressure.
    budster's Avatar
    Dec 2008
    272
    Thanks for that, Jason. When the VS first came out, and I was chatting with my rep, I suggested using vs. a booster pump. His answer was a cautious one, because, after all, they also sell the Letro and booster pump! I must fully agree with you though.
    Mar 2007
    San Rafael, CA USA
    12,085
    This thread talks more about the differences between using a booster pump vs. the IntelliFlo. A separate booster pump produces up to 50 PSI at a low flow rate (< 25 GPM). At its maximum RPM of 3450, the IntelliFlow at 20 GPM produces 94 feet of head or 41 PSI using 1620 Watts and this would be on a dedicated line. So as Jason says, it is on the edge of providing enough pressure at low flow rates, depending on the type of pressure-side cleaner you use. Basically, a dedicated booster pump is specifically designed with an impeller shape optimized for high-pressure, low-flow.
    The IntelliFlow works great at 15 GPM on a dedicated line with The Pool Cleaner that I have and tmoss reported that it works for the Legend II, also at 15 GPM on a dedicated line.
    Richard
    Thanks for the additional opinions.
    I think what I'll do is experiment with return line valves and reducers to see if I can get sufficient pressure for the 180 to work with no booster without blowing the filter.
    Filter specs state 62GPM and max 40 psi
    Assuming spishex is correct that 180 needs 30psi I will try to get 30 psi with < 60 GPM and see how the 180 does.
    If it doesn't work out I'll re-address the booster vs non booster cleaner.
    Pool is 18x36 with LOTS OF TREES so I want to be sure the 360 (or other non booster cleaner) is up to the job.
    Anyone willing to rent a 360 for a couple of weeks, so I can compare performance ?
    24,000 gallons
    58" x 13" ft.
    Heat siphon 5hp
    Guest
    Quote Originally Posted by Bubba
    My 2 cents, forget the 360. You won't be happy. Seriously look at a 380 or 480 or a Hayward Viper (NOT a Phantom!) with a booster pump or a robotic.
