Thread: Adding chemicals for spring start up.
    triplets&quads's Avatar
    May 2008
    North Carolina
    79
    My pool is up to 60 degrees, but I know it will fall after today because our weather is going to chilly again. Here are my readings:
    FC 0
    CC 0
    pH 7.2
    TA 50
    CYA - not sure because I am out of test chem (it has been ordered)
    Salt 2710
    Water is bright and clear.
    I am not going to turn my SWG on. I just want to add bleach, but I was wondering, what should level should I raise my FC?
    Thank you, Nancy
    I AM LOVING THE SALT WATER AND THE BBB METHOD! 15 yr old 15,300 gal ABG, with 5 yr old liner, 5 yr old AquaTrol SWG, S220T Hayward Sand Filter, 1 1/2 HP 2 speed Hayward Pump, TF100 Test Kit, 11 yr old grandson, 6 yr old grand-quads AND 4 year old triplet grandsons! ~ I AM HAVING FUN NOW!
    May 2008
    North Carolina
    79
    Re: Adding chemicals for spring start up.
    Wow, I should have proof read that post first! Sorry for the mistakes.
    Nancy
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Hey nancy.. i would bring the TA and Ph up a bit
    and i think a FC of 2ppm should be just fine
    Matt
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    If your pool has a solid cover on it, just a little chlorine will be plenty. Add 1 or 2 ppm of chlorine and you should be fine.
    If your pool is open to the sunlight, and your CYA level was 50 or lower the last time it was measured, I would add 5 ppm of chlorine in the evening. Higher previous CYA levels will need more chlorine.
    May 2008
    North Carolina
    79
    What about the pH? Is 7.2 too low? Will the bleach raise it?
    My pool is in the wide open sun all day! We did not cover it for winter. We have been keeping the leaves out and draining when neccessary. The CYA was 50 at the end of the swim season and the salt was about 3000, so I am sure I have some CYA. I should have ordered my test chem sooner! My husband is on pool duty right now taking out some leaves and I am going to add bleach. The pump is also running to help with small bits of debris. The SWG is off. No need to run it until later.
    Thanks for the help!
    Nancy
    Because you have a vinyl liner, your PH is acceptable for now. Long term you will want to raise both the PH and TA levels, but there is no hurry on that at all.
    Adding bleach won't have any significant long term effect on the PH.
