Hayward max flo pump questions
Cpool
Oct 30, 2013
86
Baton Rouge, LA
Hi,
1. I am confused on how to use the 3 timer setting on my pump. Is it possible to use 1 setting or does the pump automatically switch between the 3 settings?
2. How do I get it to run 24 hrs? I set the start and stop time as the same time but that didn't work to disable the timer.
3. When I come home from work the display is reading "Idle" or "1dle" can't tell is its a 1 or an I. Anyone know what that means?
Thanks guys.
1) set the 2 timers you don't want to use to start and stop at the exact same time. 12:00-12:00. This makes the logic ignore these timers.
2) To run 24 hours you need the timer to start at 12:00am and end at 11:59pm.
Hayward has the manuals on their website which includes code errors.
