DaninFLA
0
if you are losing 3-3.5ppm in FC per day, what is your CYA? might want to bump it up, depending on its level
the pressure rise could be normal if you have stuff in the water to filter out. but as far as adding the DE, you should check your pressure, then add a small amount of DE and re-check. you only want to add enough DE to raise your pressure by 1 psi. if you add 3/4 of a cup and your psi rises 1 psi after you add it, its the right amount. it will then climb as it collects stuff from the water and you will backwash when it hits 14 psi or so. if its raising more than 1 psi after adding it, you added too much.
Been a good couple of days. I seem to have the FC levels in check and they are about what I expect whenever I test them. I haven't been really accurate with my chlorine additions - generally go in 1/2 jug increments by feel. 1 jug is good for about 5 ppm on my pool. My pool volume seems to be a bit higher than the initial estimate shown in my sig. I seem to lose about 3 to 3.5 FC during the day to sun. This thing gets blasted by the AZ sun until mid afternoon.
My pool cleaner (automatic) doesn't work very well. It's a Hayward Pool Vac Ultra and appears to have many years on it. It doesn't go up the sides at all and can't even get to the shallow end of the pool. I haven't decided if I want to throw parts at it or not. I may just get a manual vacuum for the near term as that will be easier than swimming to the bottom with the end of the hose and trying to suck stuff up.
The filter pressure is weird. When I start the pump, the pressure starts around 10. Then over about 4 hours it slowly rises to 15-17 then stabilizes. This is with 3/4 cup of DE in the filter. Is this normal? I back washed it last night before bed and it ran w/o DE overnight. It doesn't behave like that w/o DE in the filter. I'm going to experiment more with DE amounts.
