I'm not sure now if the battle is against baqaucil or if it is against algae, because the last time any baquacil was added to the pool was around August '08 and before we had these heavy rains, the water was starting to get clear. Then on Tuesday (5/5/09) the thunderstorms and heavy rain started. Early this evening is when I actually got a chance to go check on the pool; which is when I found the water 95% green (I can see about 6" into the water but definitely not the bottom).
Seeing as I know that we have organic matter at the bottom of the pool, the plan for the next few days is to use both leaf removal contraptions to reduce it. Reading your Green Swamp to Sparkling Pool guide has brought me to that conclusion.
Once I've got the organic matter to a minimum, I'm going to measure the CYA level and adjust if necessary, I'm aiming for a level of close to 35.
pH is at 7.2 the last time I tested (Tuesday 4th) and if that has changed, I'll adjust it back to that reading.
Only once the above have been accomplished, is when I will then shock the pool with bleach. Using the Pool Calc, my shock FC target is 10 (with CYA at 35 & ph at 7.2) which for me will be 2 gallons & 3 cups of 174oz 6% bleach. At present, I only have 10 jugs of the stuff sitting in the carport, so this will also give me a chance to stock up on some more in preparation. I'm hoping another 20 jugs of the same will be sufficient to get the pool sparkling clear.
If all this doesn't result in clear sparkling pool water then I'm going to be very tempted to get a shotgun and just blow a few holes in the bloody thing. Yeah, I'm a bit fed up with the pool at the moment - sorry.
