Thread: Skimmer Basket question
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    I have two of these baskets in our pool. I am curious, what is the purpose of the rod through the top?
    I like this basket because you don't have to reach in to remove it plus it does suck water through the handle when the basket gets full of leaves. I ask about the rod because sometimes it makes it hard to get leaves out of the basket as they catch on it.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Feb 2008
    Denton, TX
    5,062
    Re: Skimmer Basket question
    You figured correctly! It's a dual purpose design which supposedly allows for easier removal, as well as permitting for water to bypass things when the basket is full of leaves or other debris. It's called a Skim Pro.
    http://www.shepnell.com/skimpro.htm
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Let me re-explain, I am not asking about the vertical handle (I know what that is for) I am asking about the metal rod that goes across the basket. It seems to serve no purpose, other than to make it hard to empty the basket.
    Polaris 280 robot
    Pool Calc user
    37,887
    The metal rod is a handle. I believe that it is intended for use when you remove the plastic "handle".
