heatdissipation, thanks.
So, it would seem putting the Tcell on a schedule is kind of worthless? If it is "ON" all the time. Might be better to just set it like you do and that's it. I'm going to run a test and turn on my filter outside of the schedule and see if the Tcell starts chlorinating at all outside of the schedule.
I turned on filter outside of the normal schedule. The T Cell does appear to chlorinate.
Mine behaves the same way. I believe it will chlorinate whenever the pump is on - or maybe it's technically whenever the flow switch detects flow? I called Hayward about this when I initially got the system up and programmed, and was confused by the fact that I had set a "schedule" for the chlorinator, but yet it was "ON" all the time. I was told that the schedule for the chlorinator is not used / would be ignored, and doesn't need to be set up. In my opinion this is a User Interface bug (i.e. if you don't need a schedule, and it is ignored, then it shouldn't even be an option).
Also, I've only had the Omnilogic for a month or two, and it's been mostly pretty hot out, but a couple nights the outdoor temps dropped a bit, and I woke up to a "T-Cell Low Temp Alarm" or something to that effect - which happened when the pump was off (and the temps in the SWG / pipes probably dropped due to the water sitting idle). I would think this alarm should be filtered out by the system - when the pump is not running, the SWG should be OFF, and it shouldn't generate a low-temp alarm.
Just yesterday I got a "Clean T-Cell" alarm (or something similar) that I cleared manually. Does anyone now if that is just a periodic alarm, or whether it means that the OmniLogic detected something from the cell that indicates it needs cleaning? I've had the cell since the beginning of last summer and it has not been cleaned yet...
