Pump problem
Jul 21, 2015
1
Tn
I have a summer escapes above ground pool. I think it is 15' diameter. I'm not sure if the pump is working. I hear it running, but my pool gets nasty quickly regardless of adding chemicals. When I look in the pump, I see water around the filter, but not in the middle of the filter. No water is getting to the chlorine tablets in the center of the filter. I change the filter at least once or twice a week. Any suggestions for troubleshooting?
unfortunatly you are about the 5th person I have seen this year with that type pool and pump issues... here is one I answered a last month..
broken impeller shaft!!
I am not sure if or how it can be fixed... is there any way you could get another pump?
