Make sure to test your well water for metals before you use it. Don't want to cause more problems.
It would be a good idea to test it even if you end up not draining the pool.
IF you do choose to drain your pool you will need to leave at least 1 foot of water in your pool to make sure no damage is done to the liner.
You CAN clear it just using bleach/chlorine. I am not sure if draining and refilling will help speed up your SLAM. I guess the thought is that your will have some non-algae water in the pool BUT during the time you are draining and adding water your "old" water will be sitting and the algae will keep growing.
I guess it is 6 of one and 1/2 of another.
Kim
Kim
