DaninFLA
0
diluted muriatic acid will remove the scale really quick too, you can do that while you are draining.
New pump is installed and my test kit came today. I've read the instructions, watched the videos, etc. but I want to make sure I'm doing this right - for the chlorine drop test the water turned pink after adding the scoop of r-0870 but adding the r-0871 solution kept making the water darker and darker pink until it was a dark pink/purple color, this was after 60 drops, I wasn't sure if I should keep going or if I was doing something wrong or if my FC is really high and after a certain number I could just stop b/c it was so high so as not to waste drops?
Feeling really frustrated and clueless - in addition to not knowing what is going on with the chlorine test, in the Calcium hardness test, the R-0012 never changes the color from red to blue, it goes from red to clear?
TA: 90 (my test went from blue to yellow instead of green to red)
CYA: I'm not exactly sure, I couldn't see the black dot a little more than halfway up from the bottom of the tube to the 100 mark so that indicates it's really, really high, correct?
Ph: not sure, the color was much more yellow than any of the comparison colors.
I'm guessing we are going to need to at least partially drain the pool due to the CYA? The other thing I am wondering is we have what I assume is calcium scaling on the sides of the pool right above the water level, the company that installed the new pump recommended draining the pool and bead blasting it (I think that was the term), I'm not sure if this is a good idea or what the alternatives are for removing it or if it's ok to leave it as is? I will see if I can post some pics...
