drop in steps keep floating
I have a pad under mine and I put a 10# weight on the platform that is behind the steps. My other set of steps, per instructions, are filled with water. Some people fill pvc with cement, cap the tube, and hang it on the steps. Search the forum for some ideas on how to weigh down pool steps or floating steps. Lots of information is available.
On the pads, is there a specific type of pad I should get? if it is something that does not sink and stay on the bottom, then it wont work since these steps doont actualy touch the bottom unless someone is tepping on them ( or hopefully when I add the weights as recommended above)
I can't find the instruction manual and I don't see where the make our model is. Do ant of you know what it is?. Here's a pic of the back of the steps
