TA - 250 How do I lower this Need Help New to doing this - I am Using 6-way test Kit
Jul 28, 2014
17
el paso tx
I just filled the pool 3 days ago, using the 6 way test kit this is the results
I thought I had done something wrong this morning when I tested for TA - I got same results this evening.
FC - 0 per pool math going to add 76 oz bleach
PH - 7.5 ok
TA:scratch: 250 I don't know what to do
PH - 7.5 ok
What FC level are you targeting? What strength bleach?
What are your plans for stabilizer CYA?
Why the concern over your TA? Are you having pH issues?
You should be more concerned with getting a better test kit.
Anyhoo, a trip to Pool School is in order. IMO unless you are having trouble maintaining pH your energy would be better spent getting a steady FC level.
http://www.troublefreepool.com/content/129-how-to-lower-lowering-total-alkalinity
Dom
