Thread: info on ladders and install???
    Feb 2008
    Ohio
    156
    I want to add a step ladder to our deep end inground pool (currently no ladder) So, looking at the basic 3 step ladders...do these just anchor from the top deck? and are they difficult to install?? My husband is deployed so I'm taking on some projects...just got done tiling our foyer
    I'm dreaming of warm weather and was thinking I could add the ladder myself. any thoughts or advice??
    thanks,
    chris
    30-40yr old prehistoric IG gunite 20 X 40 approx 30000gals
    now with new cool blue Diamond Brite and blue waterline tile (looking good for 40yr old pool)
    new Hayward 244T sand filter, 3/4 Hayward pump, Jandy heat pump
    pool skim (love it)
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: info on ladders and install???
    What type of deck do you have? Concrete?
    Feb 2008
    Ohio
    156
    yes, concrete (sorrry, i guess i should have said that)
    pool skim (love it)
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Virtually all SS ladders (from SR Smith and Interfab) are made for in-deck anchors, rather than an "on deck" installation, but they also make "on deck" anchors that could be used, knowing that you still have to drill into the concrete to place the anchors.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    You'll need some sort of an anchor to attach the ladder to. You can either remove some concrete and set them in place like you would with new construction, or bolt them onto the top of the existing concrete.
    Since you're doing this after the fact it might be difficult to connect your ladder to your bonding grid, especially if you use the bolted down deck flange. SR Smith makes a whole line of products called SealedSteel that work around this problem. They have plastic anchors and coated ladders so no bonding is required, but the anchors do require taking up some concrete.
    Here are the two different basic types of anchors:
    Flush with deck:
    On top of deck:
