100% new to pools. Design video etc
dunginhawk
230
CLIVE/IA
#1
Good evening folks.. So i found this forum while searching for ways to sanitize pools etc. I found ecosmarte (which was pretty quickly debunked by some of you folks, and havent seen the OP come back to defend it) I have looked at DrinkablePoolWaterSystems (new ish) which sounds promising, but again, could be complete garbage.
Be that as it may
I am shopping installers, options, etc. I have never owned a pool, but the older I get the more I realize i want one.
Married, 2 kids, 4/6, they are jacked.
So, I wanted to get some input and advice etc on my build, options, etc.
I modeled my home, then the backyard, then the pool etc.
Keep in mind, the grey patio where the fire pit is, is already existing. The Stone wall, is as well. However its a solid wall today. My idea is to break it open in the middle and have that be an entry to the pool (i think it looks good)
The awning over the couch area is also not there today. That door (near couch) will be a new door, leading in to a current guest room. That room will be tiled. Across the hall from that room is a bathroom. It seems like a very quick, easy way to eliminate the need for a formal pool house + bathroom etc. I plan to put an air curtain up above the french doors to allow those doors to be open, and bugs and air conditioning to remain in their respective places.
I am pretty set on a fiberglass pool ( i know up front cost is more). I just feel the maintenence, etc is so much less. I dont like the wrinkling in vinyl, the look over time, etc...
So here is the video i created.
LaBarre Pool Project - YouTube
Ok... chemicals. I hate the idea of chlorine. Not as a sanitizing agent, but as a skin drying, eye irritant. Is there any way around this?
Salt water chlorine pool.. Is it really that hard on pumps, etc? I know id have to replace the cartridge every few years, I can handle that, but other than that is it that bad on everything else? Also knowing I am going fiberglass, might that make salt water more appealing?
Im still in the information gathering phase, as you can tell. I just want to make the best decision possible.
thank you folks
YippeeSkippy
9,091
Evans, Georgia
#2
Awrighty then! Welcome to TFP :)
You obviously have never been in a TFP pool. The only pool that causes dry skin and eye irritation is a *badly managed* pool! Chlorine, especially as we promote using it is the safest, cheapest and best way to keep a pool clean and clear.
A salt water pool *is* a chlorine pool. Its just that the chlorine is made by the device from the salt in the water.
Chlorine protects you from person to person disease transmission. Ozone does not. Ecosmart is based on copper which can screw up and stain pools bad and turn hair green, as well as still requiring chlorine to prevent disease transmission.
EcoSmarte
I love my fiberglass pool... its one weakness is that *if* you're going to have metals in the water fiberglass pool metal stains are a PITN to remove. Solution is to just say no to metals!
Maddie :flower:
dunginhawk
230
CLIVE/IA
#3
THanks Maddie... I do know that a Salt water pool is a chlorine pool. Just curious as to what people prefer these days :) Good to know about metal objects in a fiberglass pool. I remember seeing something a while back about that.. need to commit it to memory :)
jaymantx
145
Houston/TX
#4
Hi there,
I stopped watching your video as soon as I saw the brick coping. There’s nothing wrong with it, but it’s considered a little out of date. Consider travertine or limestone coping. Travertine coping used to be considered an “upgrade” in the past, but now many pool companies offer them as a standard.
dunginhawk
230
CLIVE/IA
#5
The brick coping was just something I put in... It will NOT be my selection... 99% sure its just stamped concrete bullnose coping... ive already changed it in the program haha
dunginhawk
230
CLIVE/IA
#6
Right now this is an angled grade that I want to level off (like this picture) and put all my pool stuff under there. pumps, heater etc. (btw the pillars along the walls, and middle are NOT there IRL)
I want to start doing some of the work of subbing stuff now before the pool goes in etc. My question is, how should I pour this pad knowing pvc etc has to come in here at some point... do I just leave a 3x5 section unpoured so the pool guys can trench in? create a 3x1 rectangle in a certain spot that they can fish in to? Id love to feedback here. I do hope to get this done prior to pool, because if i can piece out some of these 2k$ jobs along the way, the downstroke of the project is lessened :) in my head
Geebot
694
#7
EcoSmarte
Maddie :flower:
To add to that, a properly maintained pool has the correct level of chlorine, which is consumed daily through normal use and normal dissipation (if you ever owned a goldfish you'll remember that the pet shop told you to fill the bowl and let it sit for 24 hours so the chlorine would dissipate). A saltwater system is the easiest. I prefer to add liquid chlorine manually (I test and balance every morning). At the proper levels you can barely tell it's there.
dunginhawk
230
CLIVE/IA
#8
While I completely understand there is a lot of ongoing maint with a pool, every day seems a bit overkill for what I want to do. I would LOVE to have the ability to do some sort of work on it daily, but that isnt the life I lead. I travel for work, sometimes a week at a time. I am hopeful I can maintain my pool with a weekly maint schedule. Obviously if extenuating circumstances require, I can do it more often at times. Hoping the inclusion of fiberglass and an automatic pool cover will help maintain chemical levels and require less maint.
thanks
jimmythegreek
427
Succasunna, NJ
#9
i get what your thinking of getting the small stuff done as you go, but you rly cant. you will end up making finish work either sloppy or doing things twice. if you pour that slab and leave a trench open, its more money to do is 2 seperate times than at once, its not just square ft its sqft plus the setup and on the job charge plus additional delivery. you get the pool installed and the piping run then have the plumbers/electricians get there conduits in and leave some room in the concrete for the pipes you do not want to encase them in the concrete someday you will have to change things or upgrade/swap equipment.
after you get the pool in and it setup thats when you worry about finish work, you can only rly do structural and work to the house thats not gonna be in way of the pool guys. there are creative ways to do some other stuff but you rly gotta think ahead and if your not familiar with construction tactics or in the bizness its hard to know whats ahead w the subs. very hard to do for the average person you are at the mercy of the information the workers tell you thats gonna happen but may not be whats needed to be done exactly
dunginhawk
230
CLIVE/IA
#10
Thats understandable... for the pad, totally makes sense. What I can do is have the awning done that will cover the couch/bar area. I know that will require some base footings anyway, so getting those poured now, so i dont have to break up concrete later will be nice. then when they pour the deck they can just pour around the pillars and be done with it.
dunginhawk
230
CLIVE/IA
#11
lovely new change I found out today... our city only allows 30% of your backyard space to be consumed with pool, patio, decking, sheds etc. which severely hampers my plans. I likely need to go down to a 36' pool and drastically cut down my decking. and put in permeable pavers for my walkways... even then im still 100 sq foot above in my latest design.
man, what a pain in the arse
ajw22
3,313
Northern NJ
#12
In my opinion a concrete pad over the PVC pipes becomes a PITA when you need to do any pipe maintenance as things age. I refer gravel or river rock and you place equipment pads on top of it for your filter, heater, and pumps.
Or bring the PVC up from the dirt on the edge of a poured concrete pad and pipe above ground to the equipment.
Don't bring the PVC up under the concrete pad.
dunginhawk
230
CLIVE/IA
#13
Looks very nice :) i will go with the installers recomendation.
So, I am in a bit of a pickle. I visited one of the installers homes tonight to look at his pool, a 16x36 freeform. My wife immediately said "No", and I have to admit, i wasnt thrilled either. I mean the pool was nice. Clean and the cover was great... Hes a good pool builder, but the size just wasnt anywhere near what we want.
So Im going to ask him to look at a 16x40 hoping it changes our mind in that direction... I have a feeling though still it will seem too small. We are used to visiting friends with 20x40, and our girl takes lessons from a woman with a 20x48. 20x40 seems the right size. Freeform just takes so much space out of the mix.
The downside to going to 20x40 is that we are now in vinyl land. I really really dont want vinyl. Besides its upfront cost savings (10k) there are no redeeming qualities in my mind (i am ready to be convinced otherwise). Vinyl Wrinkles, and there isnt much you can do about it. It needs to be replaced every 5-8 years (unless you get super lucky) at 5k + each time (wiping away the savings after 10-15 years) I think the way it has to be installed is not as aethetically pleasing as fiberglass (and the bullnose coping).
Perhaps im being too picky, but when you spend 150k on an outdoor living space, you should get what you want :(
thoughts?
dunginhawk
230
CLIVE/IA
#14
SO, for those of you that had to do fences around your pool, im getting quotes for 55-60 / ft for 6ft vinyl fence... is it just me, or does that seem high? ill need about 240 ft of fence to enclose my back yard which is a cool $14,400 before gates.
MannyT
213
Pembroke Pines, Florida
#15
I just had to do my fence in my yard because of my pool that torn down by hurricane and i was charged approximately $41/ ft for 6 ft vynil pvc shadow box fence and it was approximately 155ft which included two 4ft gates. It depends on the type of pvc fence and also region of country. I hope this helps. I did get quotes that were higher.
dunginhawk
230
CLIVE/IA
#19
I havent seen a pool install bid yet.. can anyone give me any idea on what a SWG system is priced at compared to a normal non salt system?
I agree that is probably the way to go, just want to add it to my spiraling out of control budget haha.
I already have the pool picked out (WEllspring 40 by THursday Pools) and my installer, whos 10 references checked out in stellar fashion.
His concrete sub charges 6$ a foot which is pretty dang good.
His fence sub is priced cheaper by a long way (and ive seen their work) than the bids i had. So thats good.
Things are coming along. Biggest expense outside of pool stuff is going to be adding that darn awning to my house haha
kimkats
36,047
Tallahassee, FL
#20
How many gallons are you thinking the pool will be? We suggest getting a SWG that is rated 2x the size of the pool. This helps save money with lower pump run time and longer cell life.
