1 HP or 1.5 HP or more
Don12
2
Ontario
I have a 26300 gal pool which is about 25 years old. It is 55ft from the pump and filter and I have determined it to have 180 ft of head and 55GPM. I have 1 1/2 " pipe and currently a 1HP motor which now needs replacing. Could I go with a 1.5 HP pump or higher?
ajw22
28,433
Northern NJ
Welcome to TFP.
Why do you want to go higher HP when most folks are going to run VS pumps at low speeds and HP?
cowboycasey
8,645
Southern OK
Welcome to TFP :)
Low and slow is the new greatness... VS pumps are the best option right now and way better than single speed pumps...
Don12
2
Ontario
We have a sand filter, in ground, vinyl liner pool. No features other than solar powered heater on house roof.
cowboycasey
8,645
Southern OK
A VS would work perfect for your setup... You could set exactly how many hours to run the solar and how many hours to run a lower RPM for normal filtering... :)
cowboycasey
8,645
Southern OK
mas985
14,682
Pleasanton, CA
How did you determine that? There is no way you can have 180 ft of head with a residential pool pump. There would be no flow.
Hint: Head loss is related to pipe length but does not equal it.
