If I have 2" pipes throughout but 1.5" connections at skimmers, will this affect my flow rate? Am I much better off having 2" connections at skimmers? Thanks!
If you have a VS pump you should be running it at low speed and flow. Your pump VS settings will determine your water flow rate, not the size of your pipes.
