Results 1 to 14 of 14
Thread: Anyone used spray-on liner for vinyl liner replacement?
    sdmeyer97's Avatar
    Jun 2011
    Charleston, IL
    38
    We are starting the process of replacing the our vinyl liner. I have read about companies installing truck-bed-liner material as an option to a vinyl liner. Does anyone have experience with this? Pros or Cons?
    30,000 gal Inground Vinyl Liner Dive pool,Tristar pump, Hayward C5025, SwimClear Cartridge Filter, HeatPro 250k btu gas heater, Hayward Aqua Plus Goldline with salt chlorine generation,
    Hayward Sense & Dispense. Not that I understand this stuff........
    Casey's Avatar
    SW PA
    10,461
    Re: Anyone used spray-on liner for vinyl liner replacement?
    Never heard of this being used in a pool. Do you have links or anything we can read up on?
    sdmeyer97's Avatar
    Jun 2011
    Charleston, IL
    38
    Jul 2015
    lady lake fl
    14
    The stuff sounds cool, I wonder why its not used more?
    Apr 2013
    Sacramento, CA
    2,769
    Never heard of it. Any information on service life and warranty?
    Jul 2014
    Hope Mills, NC
    569
    Quick check on the square foot of my 16 x 32 pool is appx 975 at $3.50 per sq. foot = roughly $3500. How much is a liner?
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I just got a rough quote for a liner about that same size... it was around $ 2,600 for liner + install
    Dolphin E10 Cleaning Robot.
    sdmeyer97's Avatar
    Jun 2011
    Charleston, IL
    38
    Here's our issue and why we are looking into this product.....our liner is only 4 years old and has never fit "like a glove" which is what the mfr said it should fit like. It has stretched or was mis-measured so bad that it is embarrassing....our pool is 20 x 44 and the first step-down is a full-width tanning ledge that extends out 4 feet. There are at least 4 very noticeable wrinkles extending out of the ledge (going out towards the deep end) and continuing down the 3 remaining steps. Additionally, it is loose in the corners and also around the perimeter of the pool near the top. I've gotten many blisters trying to smooth out the wrinkles only to have them return while I'm smoothing out the next one. I'm tired of the wrinkles and thought this might fix it. From what I'm being told, the spray-on liner has a 25 year warranty...... any thoughts? comments?
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Does it only come in black like the truck bed liners I've seen? I wonder how that would affect your water color?
    Oops! I just saw the links and the various colors. Seems like it could be a good option. Would you care for the texture?
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    I can't comment on the pool aspect, but I did sneak Skippy's Dodge Ram truck off one year about 10 years ago and had that done to the bed of the truck. To this day it still looks brand new!
    Yippee
    sdmeyer97's Avatar
    Jun 2011
    Charleston, IL
    38
    There are texture options: fine or coarse grit, a hardener for additional strength which also smooths surface more.....my main concern is the permanence - once it's on, it's on - I can't imagine having to have it removed!
    May 2015
    kingston springs, tn
    102
    Must be the industrial version of Flex Seal. I would like to see some references - finished products. It is an interesting thought. Any idea where some of the installs are?
    18x36 IG vinyl 18,000 gal, Hayward super pump 1hp - 1.5" pipe, Pentair Triton TR-60 sand, Pentair Itellichlor IC-40 SWG, Pentair Intellibrite 5G 12v color LED light, Polaris 280 cleaner, Hayward Booster pump, Intermatic Power / Timers.
    sdmeyer97's Avatar
    Jun 2011
    Charleston, IL
    38
    Installs are all over - east & west coast, midwest....I was told that it's a relatively new application which is why I'm hesitant. The installer I would be using has done several however he only started doing them in the last year or so. From what I've seen, though, they look nice!
    Jun 2017
    Nashville, TN
    32
    Any recent experience for anyone with a polyurea liner?
