Thread: Pool pop up's
    May 2015
    Chandler
    1
    Pool pop up's
    I recently purchased a home. I have a Shasta pool with a Hayword filter system. The Pop up's and actuator have been removed previous to me owning the home. I do not wish to re install a new system. I use the QuikClean Style 1 pop ups and 6 port 1.5" Actuator. I purchased a pool cleaner that I am happy with. My plaster is in good condition. Is there any way to cover the holes with vents or modified caps ? I only have two zones plumbed for return at this time and a total of 19 missing pop up's.
    Casey's Avatar
    SW PA
    10,457
    Re: Pool pop up's
    Welcome to TFP
    Someone with more knowledge will be along shortly to help you with this.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pool pop up's
    Good question...the manufacturer (A&A?) should be able to tell you if they make such a thing. I kinda doubt it, unfortunately.
