Thread: IC40 Chlorinator generator
    Jul 2015
    Rancho Cucamonga, CA
    2
    Hello, our pool (32k Gal). salt water. The IC40 Chlorinator generator showing green flashing light = short life. Q: can it be repair or give more life than 6 years. I just had the water checked and the reading shows that needs salt 3700 (4300/4700 range). CYA = 0 (60-99). Concern me. Is there a way to repair or overhall. I hate to throw it away Help
    Casey's Avatar
    SW PA
    10,448
    Re: IC40 Chlorinator generator
    You can try and clean the cell. See if that helps.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    6 years is pretty good. Yes, you can try cleaning with muriatc acid.
