Thread: Draining pool in Dallas, Tx
    seanol's Avatar
    Dec 2014
    Garland, TX
    8
    Hey guys!
    I am getting around to draining my pool due to very high CYA readings. See here: New pool owner in Dallas
    I got to about 2/3rds down and realized that this isn't Vegas, the water table could be an issue! I used to live there and draining was not an issue.
    Has anyone drained their pool here without issue? I have a pebbletec lining but I do not want to have to fix anything. I am also worried that with all the rain we have had that it could be an issue. I started filling now and haven't had any issues and I can always drain again next week.
    Thoughts form North Texans on this fine 4th of July?
    Sean
    My pool:
    24,000 gal Tahitian inground Pebble tec pool, Pentair 520 cartidge filter, Whisperflow pump 2.0, automatic chlorine dispenser (not used anymore), pressure cleaner Platinum Grey Pentair
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,406
    Re: Draining pool in Dallas, Tx
    Not in TX but in Florida so know of what you think...........Better to not chance it! Better safe than sorry!
    Good thinking on stopping. What is said here at TFP is to leave at least 1 foot of water in the shallow end.
    Kim
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    I'm in Texas, not too far from you. I've had my pool replastered twice in the past 20 years, which of course required a complete drain. I didn't have any problem with the drain either time. However, these replasters were in a dry part of the season (August). With our recent rains and the lakes still quite full (Lake Grapevine is still above flood pool), I don't think I would take a chance on a complete drain.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    seanol's Avatar
    Dec 2014
    Garland, TX
    8
    Thanks folk!
    I was down to about 1 foot in the shallow end. I am filling now and will retest. Should I add chlorine now or wait until the pump is running? Pump should be able to be run by tomorrow morining.
    Sean
    My pool:
    Wildcat's Avatar
    Jun 2013
    309
    Quote Originally Posted by seanol View Post
    Thanks folk!
    Sean
    Personally, though I have not drained that far down ever, I would add some chlorine as it fills. Brush to circulate after each addition until pump runs
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
